beocord 3300
This post has 5 Replies | 0 Followers
madmax100
Posts 3
madmax100 Posted: Wed, Dec 28 2016 1:06 PM
Hi everyone I am a new member I treated myself this Xmas to something I have aways wanted a b &o stereo system  off eBay  drove a 400 mile round journey   checked everything except the tape deck to return back home to find the beocord 3300 is  not working it power's up but just clicks when you press play  so I have taken the top off the find the belts are shot but I still can't hear the motor running  so how do I check the motor out to see if that is shot too any help would be gratefully received thanks ps I am over the moon with the rest
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Dec 29 2016 6:39 AM
Check if the motor is running when out of standby.
If it's running - replace belts and test the deck again.
If it's not running, check that it will rotate easily by hand.
Then check the voltage on the motor tabs. (apprx 13-14 V is to be expected).
Voltage fine and motor rotatable by hand - replace motor.
No voltage - repair power supply.
If the old belts messed up and locked the motor, the power supply will need
a small repair. Depending on the failure mode, the power supply will either not output any power at all or
output will be weak so the mechanics will feel sluggish and slow.
I can supply correct  new belts and idler wheel rubber parts.
While in there replace the two electrolytic capacitors (220uF) on the Dolby board. They are known to go bad.
I can supply those too and any parts needed for the power supply repair.
madmax100
Posts 3
madmax100 replied on Fri, Dec 30 2016 7:57 PM
Hi thanks for your help the motor was all glued up (why would they go like that) released it but still a bit of resistance at certain points , took readings at moter tabs on standby .17 and on stop 13.59 with tape in.so is the motor dead ?  If so how much would it be for a motor and belts speak to you soon and thanks for all of your help and much appreciated and all the best in the new year thanks again roland
Dillen
Posts 13,191
Dillen replied on Fri, Dec 30 2016 8:17 PM
If you can measure 13-14 Volts across the motor and it's not running, then it's dead.
I can supply a new motor (original replacement part).
Email me.
madmax100
Posts 3
madmax100 replied on Sat, Dec 31 2016 5:11 PM
Hi Martin could you just confirm you have received my email to you , we live in the country side and the Internet isn't great thanks
Dillen
Posts 13,191
Dillen replied on Sun, Jan 1 2017 5:05 PM
Yes, I got them all.
Page 1 of 1 (6 items) | RSS
