My BL5 are placed in the middle of my living room (+/- 3.5 m apart from each other) and close to the wall behind them (+/- 0.5 m). My listening position (sweet spot) is +/- 2.5 m perpendicularly from the speakers.
Even though the BL5 have a great off-axis horizontal dispersion, I've rotated them pointing to the sweet spot for aesthetics reasons...
Now, the tricky part: does anyone know if I have to rotate the speakers, so that the calibration mic is perpendicular to the wall behind them, before triggering the calibration process?
Cheers, Dante.
Barry Santini:No! Calibrate in listening positon
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
Given the long wavelengths of bass notes I doubt it make any difference. Wavelength at 20 Hz is 56.5 feet.
Jeff
The earlier answer is correct: place your speakers, then calibrate. If you move them (rotation is included as a movement) then re-calibrate.
Note that the ABC measurement does not measure things like distances to walls. It measures the radiation resistance on the loudspeaker. On other words, it "sees" the entire room as a "thing" that "pushes back" on the loudspeakers' radiation differently at different frequencies. That resistance is, in effect, a measurement of the entire room's "magnitude response" effect on the loudspeaker in its location. It cannot "see" individual discrete objects or attributes of the room (like distance to walls) - although changing objects, their locations, or the wall distances, will have a resulting effect on the radiation resistance.
Cheers-geoff
