Ralf is corect. Once you have speakers attached to the BV-8, you must go into it's sound menu and register the speaker type and then assign each speaker's role. We never got the 26' here in the US, and some software may be different; but start with the TV on, press menu twice, select Options, then Sound, and then to Speaker Types, then Roles, then Distance, and finally Levels.
Let us know how that goes!
Russ
We kid because we love.
chucky:This is the cheapest version ever. Only 1 powerlink and no sound menu where you can select speakers. You need to press your beo 4 sas the manual and select speaker1, 2 or 3. Normally in a bv eg 7 or 6, you can select them in the menu even wgich one but not on a bv8-26 Thanks Chucky
Thanks Chucky
I have checked my BV8-32 manual and settings.
Like your BV8-26 my BV8-32 only has one powerlink output, so logically all you can get is stereo ([SPEAKER]+[2]) or [3] where you use the BV8's built-in speaker as a voice central channel. [1] of course only gives you the voice channel.
What speakers do you have attached to the powerlink socket ? I guess you are using a Y splitter cable like me, or have you daisy chained your external beolab speakers ? Just check they are correctly set as Left and Right with their switches.
The SOUND option (press [MENU] [MENU] to get the options list) gives me Speaker Position 1 or 2 - but this is to control bass behanviour depending upon how close the BV8 is to a wall.
BeoNut since '75
