Hi everyone,
I am new to this forum as a member and I was wondering if you could help me out?
There is so much expertise here and so much love for the product...that someone must be able can to give me some advice.
I recently bought an Beomaster 9000 M & an Beogram 1000 VF but i don't own a pair of solid speakers.
does anyone have some advice/tips? I would like to them in the style of my other components, for instance the s45?
Hope to hear from you!
stefan
Somedays I need the music & some days I need the lyrics!
s45 are really surprisingly good, I Was using wharfdale e45's until I got a pair of s45-2 was intending to not keep them until I Heard them really good speaker cant go wrong with those
Thx. For your reply! Good to hear that you have some good experience with the S45, I think I'm also gonna take a look for a pair!
thx again.
The S45s are great speakers though not really of the same era as your kit! Beovox 1200s are a good match. Earlier B&O was very much designed as a set and although individually units might have some weaknesses, the sum of the parts was often considerably better than expected. Get the right 1200s though!
But if historical accuracy is not that important, S45.2s are frankly superb.
Peter
Peter, thx for your advice & info, great to hear. I just found sone speakers im not familiar with, maybe you guys are?
The beovox type M & the B HT-33, anyone knowd about the year, sound & price?
thx.
https
These are the B HT-33.
