Beosound 4 - Autoshutoff
This post has 1 Reply | 0 Followers
sodoi18
Posts 23
sodoi18 Posted: Tue, Jan 10 2017 9:35 PM
All:
I have  Beosound 4 shutting off after may be 3hrs of operation. I thought the fix would be to access the customer service menu and set it to OFF mode.
However, when i got into the service menu I cannot find the Autoshut off as an item in the list.
I used the 00 GO option from the setup to access the service menu.
Is there a way to fix this problem. Or is there a fault with my system. One more thing I may have to point out is I have a beosystem 4500 connected to Beosound 4 via the AUX
Thanks for any helo
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Has this previously worked without problems or have you always had this problem?
Under "SETUP" then "OPTIONS" do you have the TIMER set to ON?
Regards Keith....
Page 1 of 1 (2 items) | RSS
