Hi All
I have just bought a beosound 2 and am very pleased. when i turn it on( one tap ) it appears to be playing a radio station I think, no talking just music any ideas.
hers how I set it up.
1 plugged in to mains power and Ethernet cable for WiFi.
2 I use my android phone to play spotify and have the beosound 2 selected.
As i read this I think it might be a hard question to answer but ,people are great maybe somebody knows
Hello, I have the same strange behavior... I didn't activate any Spotify or Tunein account. Only using airplay, but when I tap on the top it starts playing something like a radio station. And when you slide on the top panel the station changes...
It is the built in Tunein Netradio that is playing. You can deactivate that in the Product Settings then Content Sources and uncheck Tunein in the list.
I have unchecked Tunein and Qplay and Spotify from the beginning and still playing...
