beocom 2 can receive call but phone call are not possible
This post has 3 Replies | 0 Followers
olvisab
Posts 1,391
olvisab Posted: Mon, Jan 23 2017 5:52 PM
hello
I have just bought a pstn mk1 with a beocom 2 and I tried to make it work.
the base is recognized and I can receive call. The beocom 2 rings and I can speak and hear the conversation.
the problem is when I dial a phone number. the phone number is composed but then nothing happened. the phone I call doesn't ring at all.
however the screen of the beocom shows the duration of the call like if I was online.m
standard is set to off.
thanks in advance for your help
4 beolab 5,  beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2,  2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
Ralf
Hamburg Germany
Posts 189
Ralf replied on Wed, Jan 25 2017 9:17 AM
if you just press the Line Button (without any numbers), do you hear a tone, can you make INT calls?
Review your Base settings, may be it is configured to be connected to a telephonsystem using Flashsignalto get a free line, switch it off.
Is your base directly connected to the provider or with an adaptor or telephonsystem?
Ralf
olvisab
Posts 1,391
olvisab replied on Wed, Jan 25 2017 12:48 PM
hi ralf
thanks for your help.
when I compose a number I hear a tone and hear the number being composed. Then I don't hear anything. The number I call doesn't ring.
I have done nothing with the base, only registered the beocom 2.
the beocom 2 base is plugged into the phone input of the box of my adsl provider without any adapter in between.
the beocom 2 rings if I call him.
olvisab
Posts 1,391
olvisab replied on Wed, Jan 25 2017 12:49 PM
I have only one b&o phone, so I cannot make int calls.
Page 1 of 1 (4 items) | RSS
