Beovision 7 40 type 9443
This post has 1 Reply | 0 Followers
bramble
Posts 397
bramble Posted: Fri, Jan 27 2017 1:46 PM
Hello folks, Just changed my bv5 up to a bv7 40 hd with blue display on screen with 7.4......all good apart from the ir to allow me to use beo4 on sky box Can I use the old one that worked with bv5? Is there any settings I need to change And last but not least..... were does it plug in Rgds
Beovision 7 40 mk 5 ,beovision 6x3,   beosound 3000, beogram 3300 , 2 x lc2, 2 x beocom 1401, beocom 6000 x 2,  5 x beo4,
, 4 x beolab 4's, form 2, h2, a2,a1 and a beolab 2 😀😀
Millemissen
Flensborg, Denmark
Posts 14,680
I guess you mean 'control the box with the Beo4 using a PUC in the tv'?
In that case, you would have to have the same code in the BV7 and - similar to the BV5 - use the ir-cable for the physical connection to the box.
And you'd have to have the input setup to use that code.
Page 1 of 1 (2 items) | RSS
