Beolab 3500...I'm lost
This post has 1 Reply | 0 Followers
BenSA
Durban, South Africa
Posts 1,404
BenSA Posted: Fri, Oct 20 2017 7:03 PM
So i bought 4 beolab speakers from B&O....because they were such a bargain and came with stands etc. Only cost R6000.00...couldn't say no.
So I hooked one up to my beosound 3000 via masterlink. it works but its so much softer than the Beolab 6000's. At 40 the Beolab 6000's are so loud and the 3500 is super soft. They all do they same thing. Is it because I have connected it incorrectly. If play it on its own then I have to play at least 60 to get some volume.
I tried a beolink 1611 with it but could not get any sound coming though. Wouldn't go to A.Aux on the 3500's. I have never used a link system as I just put a B&O in every room lol. Its really more complicated then i thought.
Basically I don't understand why they so soft!!
Ben
BenSA
Posts 1,404
BenSA replied on Fri, Oct 20 2017 10:27 PM
Worked it out!! Just needed some patience!
Page 1 of 1 (2 items) | RSS
