Beoplay V1 and Beo5
This post has 1 Reply | 2 Followers
jans
Belgium
Posts 394
jans Posted: Wed, Aug 8 2012 12:57 PM
Hi.
This is my first post to the forum. After being a satisfied user of a Beovision 6-26 for years, I am considering to buy a BeoPlay V1-40. In my current set-up, I am using a Beo5 remote control for my BV6, a Beosound 3000, my Beolabs 8000 and a STB.
In the new set-up, I want to connect a STB, my Sonos system, a DVD player and the Beolabs directly to the Beoplay V1. I probably will not be using my Beosound anymore in this set-up.
Is it possible to continue using the Beo5 remote control with the BeoPlay V1, or is required to buy a new Beo4? I will also have to make some changes to the Beo5 programming. Is this something I can do myself, or do I have to ask my dealer to do this?
looking forward to your answers,
Jans
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Aug 8 2012 1:39 PM
Welcome to Beoworld Forum!
The V1 user manual refer to Beo6, so I assume that it should be able to use a Beo5 as well.
Your dealer have to do the changes in the Beo5 for you, unless you get the configuration software from somewhere.
Page 1 of 1 (2 items) | RSS
