Beolab 2 keeps turning off when activated on beovision 11
This post has 1 Reply | 0 Followers
Rob - Danish AV
Melbourne
Posts 376
Rob - Danish AV Posted: Sun, Feb 19 2017 6:51 AM
Hey everyone,
im having a bit of trouble setting up my beolab 2 to my beovision 11. All via powerlink/rj45 adapters
ive only got 1 speaker group, which consists of the inbuilt TV speakers, beolab 9's and beolab 2.
i can assign the speakers to the power link fine in the menu, They all make noise, but when I save settings the sub goes into standby.
funny enough, I have a profile set on the BeoRemote 1 and the sub works on that profile...
Should there be a power link connection dedicated to sub? And do I select sub left and sub right in settings, and the other speaker settings do I select beolab 2 twice? As it come sup twice.
I should add, the device I'm trying to setup is a Foxtel digital receiver, so would the output of that make a difference via hdmi?
im not sure how to explain better, but if you have a question I will assist best I can.
Rob - Danish AV
Melbourne
Posts 376
Worked it out, turned off Eco mode.
Page 1 of 1 (2 items) | RSS
