Beo6 Connecting to WIFI
badgersurf
Posts 539
badgersurf Posted: Mon, Feb 6 2017 1:51 PM
Hi All,
I have just brought a second life BS5 , so its the first time I have needed to activate the wifi on my Beo6.
I have turned on the wifi in the remote and then found my network, I add in the password and it never connects, I just get the message connection failed.
I have even tried putting the remote on top of the router to ensure it has maximum signal.
I have tried turning the router off and on, turning the Beo6 off and on, even swearing at it or talking nicely to the remote have failed to work.
Anyone else know what I can try / doing wrong?
Toby
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Toby,
What kind of router are you using? Make and model.
The reason I ask is that the Beo6 does not support 802.11n, only 802.11 b/g so 2.4 GHz is supported, but not 5 GHz.
Beo6 can connect to an access point that uses this protocol, but when searching for data, Beo6 will drop the
connection.
Second point, if you go into SETUP > WIRELESS > BEO6 INFO do you have a valid IP address or do you see 0.0.0.0 Also in the same screen does the SERVER IP show your router IP address normally 192.168.1.1
Regards Keith....
badgersurf
Posts 539
Thanks for your help Keith, I had added a AP point at some point as a temporary fix when my router kept losing wifi, with this turned off the beo6 connected.
Toby
Page 1 of 1 (3 items) | RSS
DigiCert Secured Site Seal
