5V power for USB feed on beomaster5500?
This post has 5 Replies | 2 Followers
tiwang
Denmark
Posts 9
tiwang Posted: Wed, Feb 8 2017 8:29 PM
hi out there
I have added a chromecast audio as "tape"- and want this to be turned/powered when I turn on the 5500 -ideally would be when I activate "tape" but I can live with that it turns on when I turn on the 5500
It is powered by a USB cabel
Where would you suggest that I pull out the power for this on the 5500?
br /tiwabng
StKong
Copenhagen
Posts 320
StKong replied on Wed, Feb 8 2017 8:31 PM
tiwang:
hi out there
br /tiwabng
Very interestjng. I am following.
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Feb 8 2017 8:47 PM
A master slave portable socket outlet might be another approach....
Ralf
tiwang
Denmark
Posts 9
tiwang replied on Wed, Feb 8 2017 9:04 PM
Hmm please tryk to Explain this a bit more in detail - I intended just to pullout 5v somewhere from the 5500 which could supply enough power when turned on but if a more flexible solution could be implemented?
Beold
Denmark
Posts 69
Beold replied on Wed, Feb 8 2017 9:36 PM
I agree with Kallasr - a "strømspare-stikdåse" would do the trick. The 5500 would be master and the chromecast would be slave and turn on when the 5500 starts using power.
Office: Beomaster 3000-2 with Beovox P45 (all in white)
Living room: Beomaster 7000 and Beogram 7000 with Beovox RL 7000 (all in white)
Kitchen: Beocenter 2300 with Beovox 4500 (not available in white :-(
leosgonewild
Helsinki, Finland
Posts 2,373
Why do you want it to turn on and off? It is a device that is supposed to be in at all times.
What I do is that I have a audio feed going to the chromecast at all times, and simply turn my audio master on and off.
Page 1 of 1 (6 items) | RSS
