Beogram CDX2 help
Lewis T
Hampshire, UK
Posts 39
Lewis T Posted: Tue, Jul 31 2012 10:40 PM
Hi All,
Just as a temporary measure I have brought a beogram cd x2 while my cdx is being repaired. I   just wanted to ask a very simple question that i couldn't find out through a Google search. When the beogram CDX2 reaches the end of the CD should it automatically go into standby ? Just wanted to double check this because I have never known a CD player to do this before.
Many Thanks,
Lewis
tournedos
Finland
Posts 7,357
Not sure about CDX2 in particular, but most B&O CD (and record and tape) players go into standby after the record ends.
I would consider it abnormal if they didn't - what purpose would it serve to have it stay on?
--mika
Dave Farr
France
Posts 2,283
Hi Lewis,
my CDX2 goes to standby when the CD has finished.  This seems a logical thing to do and is normal.
Dave.
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Wed, Aug 1 2012 5:49 PM
tournedos:
My only B&O CD player, the CD X, does stay on after playing a CD.  At least for a week or two, anyway, which is the longest I've left it on between playing CDs.
Lewis T
Hampshire, UK
Posts 39
Lewis T replied on Wed, Aug 1 2012 10:02 PM
Hi Dave,
Thank you so much for your fast reply It has put my mind at rest to be honest as every other bang and olufsen machine i have had has never gone into standby once its finished.
Thanks once again,
Lewis
Steffen
Denmark
Posts 1,408
Steffen replied on Thu, Aug 2 2012 11:53 PM
Rich:
Yes -because it's the only one with a physical on/off switch - Wink All the later models went into standby when the CD was finished.
Page 1 of 1 (6 items) | RSS
