Essence strange behaviour. Help needed!
This post has 16 Replies | 2 Followers
jans
Belgium
Posts 394
jans Posted: Sat, Feb 11 2017 4:12 PM
All
I bought an Essence last week. While I do like it in general, there is some strange behaviour which I can't get fixed. I can't switch back from "Music" (from my ipad or from a DLNA Twonky Server) to TuneIn Radio. When I select Radio the app shows that I am switching to TuneIn. The Radio logo pops up, however streaming does not start. This behaviour is the same via the app, the IR eye Join button, or the Beo4 remote.
Does anybody know how to resolve this?
I already posted the below message to BeoCare, but they had no immediate answer. A ticket has been created for the technicians.
"This week-end I have bought an Essence Mk II for the kitchen. In my living room I have a V1, so I can enjoy the multi-room experience, which is great!
In the kitchen I have an IR eye to control the Essence.
I have one problem when executing the following sequence.
- Switch from TuneIn to Music works fine. Music from my Twonky DLNA server on the iMac starts to play.
- Switching from Music to Radio (TuneIn) does not work. When I press the Radio button on the Beo4 remote, the Music stream stops. I can see on the BeoMusic app that the TuneIn Radio Logo appears. However, the TuneIn Radio stream does not start. I also don't hear the "beep" that the Essence normally makes when switching sources.
Executing the same sequence with Spotify works (TuneIn --> Spotify --> TuneIn).
How can I solve this? I assume I am on the latest software version: 1.10.6883.xxxx"
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Feb 11 2017 4:35 PM
jans:
do you mean RADIO? or do you choose TuneIn in the Beomusic app?
Or did you press Radio on the remote? How did you "connect" this command to the TuneIn of the Essence mkII.
Chris
Ostend-BE
Posts 1,170
Carolpa:
jans:
Check the log and is it the same fault?
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Carolpa
Posts 1,700
Silver Member
Carolpa replied on Sat, Feb 11 2017 4:44 PM
Chris:
Carolpa:
jans:
Note: my Essences do not show this behaviour!
jans
Belgium
Posts 394
jans replied on Sat, Feb 11 2017 5:05 PM
Carolpa:
Chris
No I don't have the same error message. I only see some messages related to Deezer login failures. This seems logical as I don't have a Deezer account.
I guess this behavior is related to the software update at the initial setup. I saw an error message, but nevertheless it seems I am on the latest software. Is there a way to force the Essence to reload the latest version?
Carolpa
Pushing the Radio button on a Beo4 activates TuneIn on the Essence. Chris already posted a chart showing the BeoRemote One and Beo4 behavior with an Essence.
Jan
Chris
Ostend-BE
Posts 1,170
Chris replied on Sat, Feb 11 2017 7:05 PM
jans:
That's clear, I try to replicate it tomorrow.
Aussie Michael
Melbourne, AU
Posts 3,730
Isn't it netradio as opposed to radio?
jans
Belgium
Posts 394
jans replied on Sun, Feb 12 2017 11:30 AM
Chris:
I did some further testing in an attempt to check what would cause the problem.
So I tried the following:
- connect wired instead of wireless: no change.
- disconnect from the Beolink Passive and the IR eye, and setup the Essence in an integrated way with the V1. The problem remains the same.
So when switching from Music to TuneIn, the app shows the logo of the Radio station but no sound. On the Tv screen there is a message saying "connecting", but nothing happens.
Anyone else who has the same problem?
Jan
egges
germoney
Posts 303
egges replied on Sun, Feb 12 2017 1:00 PM
have you checked in the BeoSetup app your contents>sources>local list? my M5 was disconnected from TuneIn three times since the marvellous Airplay-update. its since five days that it stays connected
Wohnzimmer: BeoVision Avant 55", BeoLab 11, 12-2 und 12-3 für 5.1-Sound +  appleTV 4K und Philips BluRay-Player; BeoSound 2, BeoSound 3000 (fast nur noch Deko)////Schlafzimmer: BeoEssence MkII, BeoLab 4000 + Samsung 46"-TV////Büro: BLC NL/ML, BeoSound 35, Thorens TD320MkII, Samsung 32"-TV, WesternDigital 4TB-Server////Bad: BeoLab 2000; alles CAT7 verkabelt////Küche: M5 (drahtlos) plus diverse apple-Geräte (imac, macbook, ipads, iphones, timecapsule, watch)
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Feb 12 2017 1:29 PM
jans:
As I cannot replicate the problem, I feel sorry that Ican't give you further help.
Changing from TuneIn, Deezer, DLNA music or vice versa with the remote works perfectly. The same goes with the Beomusic app. I tried also with changing to multiroom, and again only with the passive. But it keeps giving me no fault in using the Essence.
Sometimes it acts a bit slower, because I change sources or tracks probably to fast, and then I get the impression nothing is reacting. But being patience, after some seconds it changes. The Essence is wired connected, as is all B&O.
CB
> You are Here <
Posts 1,762
CB replied on Sun, Feb 12 2017 2:13 PM
jans:
May be obvious, but did you try to:
  • Reset the Essence by pushing the button at the back and reinstall it from scratch (and wired to your router)
  • Uninstall/Install the apps (Beomusic & Beosetup) completely
  • Use another device (iOS, Android, Mac or PC), eventually with a different OS version.
jans
Belgium
Posts 394
jans replied on Sun, Feb 12 2017 4:25 PM
I did a reset with a paper clip on the back, but in a wireless setup. Didn't change anything. Would wired make a difference?
I really feel I would need to re-install the latest software version. Resetting to factory settings doesn't change the software version. Any idea how I could force the Essence to re-install the latest version?
Thanks all for trying to reproduce the issue, and suggestions ways to resolve it. Unfortunately, the issue is not yet resolved. Next week, I'll try to pop in at my Dealer, and see if we can reproduce the problem and find a solution in his settings.
In the mean-time, I continue with the workaround, which is to go from Music to Spotify to TuneIn instead of directly from Music to TuneIn.
jans
Belgium
Posts 394
jans replied on Sun, Feb 12 2017 7:52 PM
Problem solved!
In the BeoSetup app I changed the buffer time from 'Automatic ' to '2 sec'. Now everything works as expected! I am very happy that I finally could resolve the problem!
Happy me! Big SmileBig Smile
Seanie_230
UK
Posts 2,278
Congratulations
I am so excited to get my Essence this week on Tuesday I have a passive and CX50's just waiting to be part of my Multiroom system.
Essence wall remote put up.
I have 3 NL devices now and one ML device.
Eclipse 65
V1-32
Beosound M5
Essence MK2
BLI
jans
Belgium
Posts 394
jans replied on Sun, Feb 12 2017 8:54 PM
My Essence is also connected to a Passive. Make sure you have the right Powerlink cable to connect the Essence to the Passive.
I am sure that you will enjoy this addition to your setup!
CB
> You are Here <
Posts 1,762
CB replied on Sun, Feb 12 2017 8:57 PM
jans:
Congratulations Smile
But what an odd issue...
The "automatic" mode is supposed to be "conservative" ?!?
Chris
Ostend-BE
Posts 1,170
Chris replied on Sun, Feb 12 2017 9:05 PM
Seanie_230:
I am so excited to get my Essence this week on Tuesday...
Sean, you bring the bubbles, we provide glasses...... Drinks
Page 1 of 1 (17 items) | RSS
