Hallo,
Which are the MK versions for the Beovision 11-46 and 11-55, and what are the thanges from one version to the other?
I found only one document giving the specifications of MK_IV versions
the pdf file is attached to my next post.
Thanks for your help
gerard
I've got a MkIV and from what I recall in discussions with my dealer during my purchase is that MkIV removed the back panel AUX input port, and changed the speaker grill attachment from clips to magnets. I think MkIII added WISA, which stayed on through MkIV. Sorry that I can't help with MkI and II.
@ Sal:
do you know if there are also MkV and MkVI and ... ?
As you can see in the MK IV document the MK IV were first released in april-2014, and technical specifications are the same for 11-40 , 11-46 and 11-55 with MK IV extension.
The Type numbres are:
BV 11-40 MK IV: 9497 9498BV11-46 MK IV: 9475 9476 9477 9496BV 11-55 MK IV: 9533 9534 9535 9536
Tuners : Standard T2/C Option T2/C/S2 Option Dual T2/C/S2 with HDD
Looking at some old pricelist I found on the net, I got following information:
Pricelist NL 2012-1011-40 : 959711-46 : 955711-55 : 9578MK IV : Introduction week 2014-1611-40 : 9497 949811-46 : 9475 9476 9477 949611-55 : 9533 9534 9535 9536
Pricelist DK 2015-06 + BE-NL 2016-01 + DK 2016-0311-40 : 947211-46 : 942711-55 : 9408
Tuners : Standard T2/C TYPE2016 Type2015 Type2012 Option T2/C/S2 4743 4743 4743 Option Dual T2/C/S2 with HDD 4745 4745 4745
