Quick Question! Beogram 8000 tonearm movement....
Zack McCormley
Joshua Tree, Ca
Posts 9
Zack McCormley Posted: Tue, Feb 28 2017 6:17 PM
Hello,
My 8000 has fallen off track. I see the little white connector on the track.
I'm not able to find the issue in the service manual.
I'm new here, and can't figure out how to post pics.... I suspect that someone will see the issue be able to help out.
Thanks!
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 3 2017 11:56 AM
The "white connector"... is that the bushing on the threaded rod you can see?
If so, it will probably have lost two of its "shoulders", allowing the carriage to move away from it.
(Typical transport damage).
Zack McCormley
Joshua Tree, Ca
Posts 9
Hi Martin,
Yes,  the "white connector" ..... "Bushing of the treated rod" That is what I'm seeing.
Do you have a photo of it shoulders? Or any ideas where I could source them?
-Zack
Dillen
Posts 13,191
Dillen replied on Sun, Mar 5 2017 4:15 PM
It's part of the bushing that has broken off.
It will most likely be intact at one end but not at the other.
Page 1 of 1 (4 items) | RSS
DigiCert Secured Site Seal
