I have a spare Ml/mcl and some mx100 speakers that I would like to set up as a stand alone system with input from a bluetooth receiver. What do I do to get the unit to switch on ?
Either:
- Add an MCL2AV with IR receiver and connect to the ML/MCL with Powerlink.
- Add Beolink 1611 converter and connect to ML/MCL with masterlink. You will need to connect an IR eye to the ML/MCL.
- Add Beolink Active and connect to ML/MCL with powerlink, thereby making use of PC input on Active.
- Add an IR eye to the ML/MCL and make use of TEST MODE 03 to open the signal path.
