Beolab 5 and Playmaker: No sound
This post has 4 Replies | 0 Followers
davelarue
Denmark
Posts 98
davelarue Posted: Fri, Feb 24 2017 3:35 PM
Upgraded from beolab 9 to beolab 5.
Connected the same playmaker setup to the new (used) beolab 5. The speakers turn on (green), but no sound...
I tried to connected by powerlink to a b&o cd player, and the speakers play fine.
Perhaps the cables from playmaker don't work with beolab 5's? They worked fine with the beolab 9.
Ideas?
Thx
Millemissen
Flensborg, Denmark
Posts 14,680
You'll need fully wired cables!
RJ45/DIN cables 6271125 (5 m) and 6271126 (10 m).
Didn't you BeoLab5 came with (!) cables?
If yes, you'll need the right adapter cables for connecting to the RJ45 output of the Playmaker (or any new PL-output).
You'll have to ask your B&O dealer for this.
Or contact Steve at SoundsHeavenly or a good local cables supplier in DK.
davelarue
Denmark
Posts 98
davelarue replied on Fri, Feb 24 2017 5:49 PM
Just to clarify: I have cables with RJ45 and Din. They were used between beolab 9 and playmaker. But, the same cables don't work with beolab 5.
The BL5's came with din/din cables.
So, i would need to purchase RJ45 adapters only then?
davelarue
Denmark
Posts 98
davelarue replied on Fri, Feb 24 2017 9:49 PM
Solved. Need thicker cables for beolab 5.
CB
> You are Here <
Posts 1,762
CB replied on Fri, Feb 24 2017 10:38 PM
davelarue:
"Thicker" cable is what MM called "fully wired" cable...
Page 1 of 1 (5 items) | RSS
