The title says it all...
I bought a Beosystem 4 and cannot get past the pincode Startup Screen, because GO button does not work.
I have an older Version of Beo 4 (DTV/V.MEM/A.MEM), no Back or Play, just Stop and Exit Buttons.The Center of the Joystick should be ENTER (or similar).
What button on my Beo 4 can be used?
Or do I Need to get a Beo 4 NAVI or a Beoremote One?
Ralf
Try using the PLAY button instead.
Regards
Opman
SELECT is the play button on the Beo4, it is in the middle of the arrow buttons
Ron
kallasr:Unfortunately it does not work...
You were part of another thread with a 7-55 with the same issue, where the solution(most likely) was to get a Navi version, it most likely will not work until you get the Navi Beo4.
/Weebyx
Unfortunately the original poster in that thread never returned to inform us, if any of the suggested solutions had worked ;-(
I'd say - get a Beo4/navi....and remember to set it to Mode1.
