Beolab 8000 and beolab 2
This post has 18 Replies | 0 Followers
andrew
Sussex UK
Posts 47
andrew Posted: Tue, Feb 14 2017 6:18 PM
Hi. I'm thinking of adding a beolab 2 to my 8000 speakers. It will be used pretty much exclusively for listening to orchestral music, opera, piano, organ  etc. The bass on the 8000's is OK but could do with a bit of beefing up. But will the beolab 2 add too much - make it perhaps a bit overblown? Advice welcome!
Many thanks
Andrew
leosgonewild
Helsinki, Finland
Posts 2,373
Pretty sure you are better of with Beolab 11 for classical.
gysse2004
Hellerup
Posts 192
gysse2004 replied on Tue, Feb 14 2017 7:01 PM
It is valentines day- BL 8000 and BL2 is a match in heaven. Think you will be disappointed with BL11.
I have had both. There is a fine bass management in BL2
peter
Beovision eclipse 65, Beolab 50, Beolab 18, Beovision 11, Beolab 3, Beolab 2, BeoVision 10, MLGW, BeoLink converter Nl/Ml, Beosound 5, BLGW
Stan
Chicago-area USA
Posts 869
Stan replied on Tue, Feb 14 2017 7:21 PM
I very much liked my BL2 + BL8000 combo.  It was one of my favorite B&O purchases.  Gave the BL8000s a much needed boost.  My BL2 is now paired with my BL1s, and I still enjoy it.  Spend a little time with the switches and placement, and, to me, it just disappears... except for the additional low end, and better mids/highs because the BL8000 isn't working so hard to produce the bass (make sure you connect them in series - Source -> BL2 -> BL8000s).
Stan
davidr
Montréal
Posts 172
davidr replied on Tue, Feb 14 2017 8:21 PM
Agree with the above, I have a BL2 and BL8000 which are a great combo. Though indeed it does take quite the trail and error adjusting the settings and more so physically moving the BL2 for best placement. I have mine set on "wall" and 2 if I remember right.
As always if you happen to listen to lowend heavy music, a sub really clears up the midrange of the mains because the woofers don't have to work (extend) so hard. From your listening description though the difference might not be so apparent in my opinion.
Mike
Austria
Posts 31
Mike replied on Wed, Feb 15 2017 6:11 AM
totally aree. I guess, you can't go wrong with that combo (as long as your room is not tiny). I had this combo too and I think the bl8000 benefit a lot from the bl2.
and in my mind, it is also some kind of protection of the bl8000 (for too much movement of the drivers)...
regards
Mike
Austria
Posts 31
sorry double post
Iceman10245
Berlin - Germany Nova Santa Ponsa-Islas Baleares
Posts 186
I had both. The BL2 was too strong to me. Then I have bought the BL11 and I pursue sen still with the BL8000. For me a good combination (room is also not so big). Of course all that is no comparison to my BL5/BL3 installation
BeoVision 7-40 HD-Modul, BeoViision 11-40, BeoVision 8 32" white + Floor Stand, 2x Apple TV 4 mit Kodi, DVD2, HDR2, BeoSound 9000 MKIII White Edition, 2x BeoSound Moment + Floor Stand, 2x BeoSound Stage, BeoSound Core, BeoSound 35 brass,  BeoSound 1 MKII + Floor Stand, 2x BeoSound 3, BeoSound 6, BeoSound 3200, BeoSound Essence ,  BeoPlay A9 Nordic Sky twilight, BeoPlay A8 MKII white + Floor Stand, BeoPlay A2 grey, 2x BeoPlay A3 white/bright blue, BeoPlay A1, 2x BeoPlay S3 white,   Beolit 12 (White Edition), Beogram TX2, BeoLab 5, BeoLab 3, BeoLab 7-4, BeoLab 8000 MKII, Beolab 11, 2x BeoLab 3500, 4x LC2, 4x Beo4 - MK1-3, BeoRemonte One BT, 2x BeoRemonte Halo, Audio Terminal, Beolink 1000, BeoLink 7000, 2x EarSet A8, 3x A9 Keyring, EarSet 2, Form2, BeoPlay H6, 3x BeoTime, Beowatch, 2x Lightmanager Pro+ B&o Version, 4x BeoCom5, Beoline2, 3x Speakerphone, BeoTalk 1200, 5x Cabinets, MLGW, BLGW,
andrew
Sussex UK
Posts 47
andrew replied on Wed, Feb 15 2017 8:19 AM
What does "connect them in series" mean? Thanks for the reply BTW.
andrew
Sussex UK
Posts 47
andrew replied on Wed, Feb 15 2017 8:21 AM
Thanks for that. I have found a beolab 2 which I shall try to buy ...
andrew
Sussex UK
Posts 47
The room is 10 feet tall but only about 14 square. Still a decent volume of space ...
Duels
England
Posts 2,553
Duels replied on Wed, Feb 15 2017 1:03 PM
andrew:
it means connect your source to the BL2 first and then your BL2 to your 8000s.  In this way the BL2 will manage the bass and filter it out before passing the signal to the 8000s.
OldJack
Split
Posts 371
OldJack replied on Wed, Feb 15 2017 2:34 PM
@Duels , I have them all connected to Bsys3,,so I can adjust speaker levels etc.Do I get any improvement connecting them "'in series'' ?
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
Mike
Austria
Posts 31
Mike replied on Thu, Feb 16 2017 9:44 AM
no, you don't. the "connect in series" set up is for stereo setups on a beosound, or for older surround setups on a beovision without separate subwoofer connection.
OldJack
Split
Posts 371
OldJack replied on Thu, Feb 16 2017 12:42 PM
Thanks Mike !
Duels
England
Posts 2,553
Duels replied on Thu, Feb 16 2017 4:15 PM
Sorry old jack I didn't see that you had asked me a question. But you now have an answer so hopefully all is good.
OldJack
Split
Posts 371
OldJack replied on Thu, Feb 16 2017 10:16 PM
All ok Duels, cheers!
andrew
Sussex UK
Posts 47
andrew replied on Thu, Mar 2 2017 1:20 PM
Beolab 2 purchased - should arrive in about a week. I do hope it sounds as good as I'm hoping! I was disappointed with my pentavox with the beomaster 7000. Years ago I had a beomaster 5500 with pentagon and I'm sure they sounded way better - the mid range sounds sort of vacant /muffled with the 7000? Anyway, very pleased with the beolab 8000 and hoping the beolab 2 will add to the experience.
Sal
California, USA
Posts 1,197
Sal replied on Thu, Mar 2 2017 2:59 PM
Congratulations! Let us know how you like it. Remember, as others have pointed out, connect your 8000s to the Lab2, and the Lab2 to your source. It's all in the Lab 2 manual.
Page 1 of 1 (19 items) | RSS
