Using a DVD1 with a Beovision AV5
Peter
Sweden
Posts 84
Peter Posted: Fri, Mar 31 2017 11:49 AM
Hi all!
I have a question on how to properly configure the AV sockets on a AV5 to use with a DVD1.
Currently I have the AV socket set to "S-VHS V.TAPE" which is the only way to use the Apple TV when pressing V.MEM on my Beo4 and get a picture from the DVD when pressing DVD on the remote.
However, I cannot remote control the DVD1 and on the small display on the AV5 it says "CDV". I cannot get it to interpret DVD from the Beo4 to DVD on the display, and I believe thats why it doesnt remote control the DVD1.
There is no DVD choice in the AV socket menu either...
Any advise what to do here?
Thanks in advance!
/Peter
Beovision 7-40 Mk VI, Beovision 3-32, Beovision AV9000, Beovision AV5, Beolab 8000, 6000, 5000, 3000, 2000,  Beocenter 2300, 9000, Beocenter 2, DVD1, DVD2, Beogram 3300, LC2, Beolit 12, 3 x AppleTV
graemeben
Posts 132
Hi.
I'm not sure if you can use the beo4 to control a dvd1 with the AV5 as the tv had a cdi player built in and which was before DVD format. B&O were not using DVD when the AV5 was selling so I think the feature you are after was probably not available.
Graeme.
Peter
Sweden
Posts 84
Peter replied on Sat, Apr 1 2017 2:17 PM
Hi Greame,
Thanks for your reply. You are probably right, it simply not compatible.
I've had the AV5 for many years, but didn't realize it is that old actually..
Cheers
Peter
Peter
Earsdon
Posts 11,991
Peter replied on Sat, Apr 1 2017 6:39 PM
It will usually work as a V.Tape player - bizarre but should work.
Peter
Page 1 of 1 (4 items) | RSS
