Beovision 7 32
laddie
Posts 1
laddie Posted: Wed, Mar 8 2017 10:34 AM
Hi All  Help please ? I have a 2008 Beovision 32 which I am trying to use with Chromecast as TV signal is extremely poor in the location. I have connected the Chromecast directly to the DVI input via an HDMI adapter but cannot tune the TV to this input or achieve any picture whatsoever. Have also connected the red/white rca leads.
Do not have much knowledge here so any feedback would be appreciated !
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Mar 8 2017 12:54 PM
Basically like this:
Setup Menu Connections any AV1 to AV4 chose connection (DTV, V.MEM or similar), chose HD input DVI.
If you choose PC to use the RCA inputs you need to add the PC command to your remote control (search forum for this).
Otherweise if you chose DTV or V.MEM you need to use a RCA to Scart and chose the Scart input on the back that matches the AVx.
Ralf
PS: Download a manual and reference guide from whereever and read it, too....
Page 1 of 1 (2 items) | RSS
