Connecting a BeoVision 7-55 to Ethernet
Benhamou
Posts 3
Benhamou Posted: Mon, Feb 15 2021 3:03 AM
Has anyone connected a BeoVision 7-55 to Ethernet?
There is an RJ45 connector in the back. It is described in the manual. But I cannot find the instructions for configuring the LAN interface.
Fritz
Posts 272
Fritz replied on Mon, Feb 15 2021 3:31 AM
The connection is only for the BD-Player, for firmware update, and BD-disk contents.
Brgds/Fritz
Benhamou
Posts 3
Benhamou replied on Mon, Feb 15 2021 7:07 PM
Thanks Fritz.
If I connect the BeoVision 7-55 to the Internet, will I be able to get firmware updates for new profiles of remote controllers? Like the AppleTV 4K remote controller? If so, how do I configure the LAN interface? Please advise.
Thanks,
beolion
Posts 485
beolion replied on Mon, Feb 15 2021 8:19 PM
Hi
It is only and solely for the Blueray firmware. I think we might have had one or two updates to that thing. That’s all.
7 series is still the old ML versions where B&O did not think it was secure to have internet connections directly.
So you need to contact your dealer to get the puc codes updated. Unfortunately.
Benhamou
Posts 3
Benhamou replied on Tue, Feb 16 2021 5:35 PM
Thanks very much
Page 1 of 1 (5 items) | RSS
