What is the benefit of the software update for the transmitter 1?
Nwisni
Posts 9
Nwisni Posted: Fri, Mar 24 2017 10:24 AM
I wonder if there is any significant improvement in performance with the software update. I can't any information on this online.
I have interference on the wireless transition when using a microwave. Would this improve with the sofware update?
Keith Saunders
Hampshire, United Kingdom
Posts 5,495
Nwisni:
A Microwave oven can often cause interference to any Wi-Fi and similar devices depending on type of Microwave, power, screening and placement.
B&O's installation manual states:-
The Beolab Transmitter 1 has an omnidirectional transmission characteristic, although this can not be an ideal sphere.
The transmitter and the receivers of the loudspeakers must have line-of sight.
The transmitter and the speakers are placed inside an area that is recommended to have the maximum of 9 x 9 metres / 30 x 30 feet
The distance between the Beolab Transmitter 1 and any receiver must not exceed 12 m / 40 ft.
Ideally there must be placed no objects between the Beolab Transmitter 1 and the speakers - especially not objects consisting of material that will block or totally material that will block or totally reflect the wireless signals.
A software update if available is unlikely to improve this interference problem.
How old is your microwave oven, if over 5 years it may well have limited RF shielding
Regards Keith....
Nwisni
Posts 9
Nwisni replied on Fri, Mar 24 2017 11:34 AM
Thanks Keith.
The microwave is only 2 years old. Most of the time we use it at 800 w
The transmitter is inside a covert in front of the speaker. It is standing next to the essence. Would that have any impact on performance?
Would you recommend updating the software anyway? Any benefit?
NIc
Page 1 of 1 (3 items) | RSS
