Hi Scott,
I know nothing of the Australian market but I can tell you that my BV11 had the optional Internal hard disk and satellite tuner fitted, so the TV has dual terrestrial and dual satellite tuners. You are best to check the available options with a local dealer.
Graham
ScottMacK:Hello all. I wonder if anyone can clarify a couple of things for me? The specs on the B&O website for many of the current televisions say they include twin tuners and USB HDD recording but with an asterisk that indicates the feature is market/broadcaster dependent. Are these features present on Australian models? Does the dual tuner facility enable watch and record at the same time? Can you record onto any USB stick, or HDD or must it be one factory installed? Thanks for your consideration. Scott
