Hi BS3 users,
Recently I retired my Beovision 3 ,purchased new Samsung UE55HU7500 , and second hand Beosystem 3 from ebay. Seller declared to be latest edition,fully working.
Intention to integrate with my :Beosound Ouverture,pair of Beolab 8000 as front speakers,pair of Beolab 4000 as rear speakers,and sub Beloab 2.
Once BS3 received,i tried to connect it to Ouverture by Masterlink,all speakers connected to BS3,but there is no sound output.Also connected TV via HDMI,but there is no any display output.
I understand I have to make setup on BS3,but i am not able to get it displayed on the screen,there is no output from BS3 to the screen.
Anybody having patience to let me know how to make proper cabling/connectios ,at least to check if my
BS3 is working or not.
Answers highly appeciated
Beogram 6500 MMC2,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beolab 7.2,Beo4 navi, 2xBeocom2,Serene,Beosystem 3 mk3,H6 2nd gen,Earphones E8,A8,A9 keyring,Beoplay A1,Bottle opener,Beoplay A2 active(thanks Botty)Wine Set(thanks Botty),4Ktv Samsung 55'',Beolab 7.1 with 42''Panasonic plasma,,Oppo udp-203, LinTronic.
As I recall, I think you you first need to connect an analog video input to the BeoSystem 3 -- such as using the yellow cable on a dvd player in order to get an initial signal. Then, you press "menu" twice to get into the setup screen. You might try that.
I"m recalling that the DVD input using an initial analogue signal is the safest choice for getting an initial signal for setting up the system. I would have the dvd player on already when you hit DVD on the remote to start up the BeoSystem 3. You might need to try different input ports (e.g. AV1, AV2, etc) to get the right one. May trying other commands such as TV, DTV, etc. It would be nice if you knew what the prior owner had assigned to each port -- such as if he had DVD assigned to AV2.
You need an ir receiver ( either part of the BV4 screen, or separate) to be able to switch the unit on, there is no ir receiver in the BS3. When the unit switches on the LED (next to the mains input socket) pulses from red to green until the unit is up and running, then the LED stays red.
Ron
beojeff,thanks
tried all of this,does not work
Thanks Ron
Will STB PUC ir blaster/transmitter for B&O tv do the job,or I need another one?
OldJack: Thanks Ron Will STB PUC ir blaster/transmitter for B&O tv do the job,or I need another one?
Look at this thread, IR Blaster will not work..
http://archivedforum2.beoworld.org/forums/t/4582.aspx
/Weebyx
Unfortunately no, you need a ir receiver that connects to the ir input ( rs232) socket. An ir blaster is a transmitter which controls an external stb or other non B&O unit.
Ok,thanks Ron!
Can you reccomend one ir receiver available on the market ,which will be compactible with BS3 and my setup?
Frane
Come on,Beosystem3 users,what ir receiver you use with BS3,which one is recommended?
Any decent proposal will be rewarded by six pack!
OldJack:Come on,Beosystem3 users,what ir receiver you use with BS3,which one is recommended? Any decent proposal will be rewarded by six pack! Beogram 6500,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beovision 3,Beocom2,Serene
StUrrock,I am not going to bother You,and any others similar to You.
Is it so hard to answer simple question: What ir receiver I need to keep my Beosystem 3 running?
Thanks beojeff!
To sum up "how to on BS3"
You'll need an IR Receiver without Auto Contrast if you are connecting the BS3 to a NON B&O panel.
Connect the IR Receiver to the system 3 using a 3mm headphone jack plug. Not the RS232
You turn on the system and go from there.
I'd also suggest to disable auto contrast in the Service Menu.
For multi room audio distribution, EVERY source connected to the BS3 has to be also its analogue connections for distributing sound thru Master Link.
Oakley: To sum up "how to on BS3" You'll need an IR Receiver without Auto Contrast if you are connecting the BS3 to a NON B&O panel. Connect the IR Receiver to the system 3 using a 3mm headphone jack plug. Not the RS232 You turn on the system and go from there. I'd also suggest to disable auto contrast in the Service Menu. For multi room audio distribution, EVERY source connected to the BS3 has to be also its analogue connections for distributing sound thru Master Link.
Be sure about this. I have a non-B&O TV and the IR receiver without auto-contrast would not work. I had to use the one with auto-contrast, and then I disabled the auto-contrast in the settings.
OldJack: Thanks beojeff!
You're very welcome. BeoWorld should be a friendly, welcoming forum and you should never be discouraged from asking for help!
It works like a charm. I've done a few "3rd Party Screen" setups w/ BeoSystem 3, including our showroom. IR only worked like a charm. Part number 8087030, you'll also need a bit of a heaphone wire with a jack. I'm unable to attache the pin out image, but if you're interested I'll email it to you.
I'm 100% sure about this. I've done a few theater setups like that including our own showroom.
You need Link Eye P#8087030 and a bit of 3 conductor wire with a 3mm headphone jack at the end of it. I'd attache the pin out image but I'm unable to. If you need/want it, I can email it to you.
Thanks Oakley
Just ordered Lintronic TT455-RT-238 with ir eye and accesories.Michael was very helpful.
Should have it here next week.
Have a nice weekend everybody!
OldJack:StUrrock,I am not going to bother You,and any others similar to You. Is it so hard to answer simple question: What ir receiver I need to keep my Beosystem 3 running? Beogram 6500,Beosound Ouverture,2xBeolab 8000,2xBelolab 4000,Beolab 2,Beovision 3,Beocom2,Serene
beojeff:You're very welcome. BeoWorld should be a friendly, welcoming forum and you should never be discouraged from asking for help!
update
Received Lintronic, with Link Eye P#8087030. Bsys3 menu accessed with Beo4 navi.All in order.Setup done straight forward.
Now working on cablings rearrangements. Next to do within day or two: awaiting amigo to help me with Lintronic setup.
Thank You , Beoworlders , for yours patience and guidance (including not a customer service center after all).
Oakley: I'd attach the pin out image but I'm unable to. If you need/want it, I can email it to you.
I will send a private message with my email address when you confirm you still have the diagram can email me.
Many thanks
Stoobie
Hi
se page 29 i think. If you screen is not on the puc table u have to use the tv's original remot to turn it on and of.
http://beointegration.com/uploaded/Idea_Catalogue_v2.1.pdf
Format 0 😀😎
Hi Thomas,
I need to attach a IR receiver to control the Beosystem 3 as it does not have a receiver built in if you connect a non B&O TV. I am not trying to control the TV but the actual Beosystem.
Thank you anyway
Hi Stoobie
To control Bsys3 with Beo4 remote,need this Ir receiver.Part number on right bottom.Attach it to IR input on Bsys3.
r
Duplicate post
Triplicate post!
Hi Old Jack,
That is good news, I already have an IR eye with that cable and it is wired as in the diagram. I'll give it a try on the weekend.
I was thinking I needed to wire it to go into the 9 pin rs232 IR socket. I hadn't spotted the smaller IR socket.
OldJack: Hi Stoobie To control Bsys3 with Beo4 remote,need this Ir receiver.Part number on right bottom.Attach it to IR input on Bsys3.
Hey Old Jack,
My system is up and running. The wiring on my IR eye is the same as my Beomedia, from where I got the eye. It is as per the attached diagram.
Thanks for your suggestions
Excellent,enjoy
