BV7-32 mk3 no sound from Oppo blu-rays
This post has 7 Replies | 0 Followers
badgersurf
Posts 539
badgersurf Posted: Sun, Apr 16 2017 7:31 AM
Hi all,
I hope some one can help.
I have had my BV7-32 Mk3 upgraded to the latest software and the chip replaced so it can do digital sound.
when I play a DVD from the attached Oppo 103 I get sound, but when I try a bluray or stream movies from my NAS I don't get any sound.
the sound goes through a atlona converter which reduces it down to HDMI and optical this then gets converters to coaxial and into the tv.
Any one got any ideas, what can I check, waiting to watch the new Star Wars film!
Toby
beosound
Posts 91
beosound replied on Sun, Apr 16 2017 8:33 AM
Set the OPPO to PCM on the audio output.
beosound
Posts 91
badgersurf
Posts 539
badgersurf replied on Tue, Apr 18 2017 12:30 PM
Thanks for you quick reply Beosound, the Oppo was set to output auto so I corrected that to LPCM over the HDMI.
But I still do not get sound, originally I thought it might then be the optical to digital converter, so tried a new on but still no sound over digital. I have check the cable that is working fine. If I use a converter from optical to stereo that works into the AV4 audio sockets. it is just the digital that is not working.
The option setting has the correct A socket for digital selected. The sound system shows Dolby Pro logic.The monitor information shows:
AP SW 7.94
IOP SW 22.0
Ac3 SW 03.01a
AVC On.
is this all correct to be able to out put from a digital source?
Toby
stefan
200 miles from Struer
Posts 2,920
stefan replied on Tue, Apr 18 2017 2:27 PM
badgersurf:
I don`t know much about the BV7-32, but I know from the BC6-26, that you have to use a certain AV socket to use the digital input. Maybe it is similiar with your BV7?
And maybe you try to use the HD  Master audio tracks - DD5.1 Hd, DTS HS master....?This won`t work via spdif, only through HDMI.
And btw, Dolby Pro Logic is an ols analog 4 channel Dolby surround, created from a 2 channel stereo track. So, this is not, what you want.
I`d try to set the Oppo to AC3 out and use an spdif output (if present) and check the assignment on the BV. Select a DD5.1 or DTS track on the BR.
Stefan
badgersurf
Posts 539
badgersurf replied on Wed, Apr 19 2017 11:19 AM
So last night I tried various converters, cables and DVD players, I can get sound out if I convert to stereo but nothing going over digital.
Can someone who has had their BV7-32 mk3 upgraded to supposedly handle digital signals and see if their information from their TVs is the same as shown in my other post above.
Toby
moxxey
South West, UK
Posts 5,359
moxxey replied on Wed, Apr 19 2017 11:54 AM
stefan:
It's a LONG time ago now (the BV7-32 is very old - this is 2004, so my memory is vague), but I'm sure that I had to use HDMI to coaxial to get audio from my DVD player to my BV7-32.
badgersurf
Posts 539
Hi Moxxy,
Thanks for your reply, I am feeding the hdmi signal into an Altima box which down scales to 720p for the picture and splits the audio into a optical, which I am then using a converter to digital (tried a few of these converters to check if it was not this at fault). If I convert to stereo I get sound but digital nothing.
I have checked the settings and connected the cable to the correct digital input. Any ideas?
Page 1 of 1 (8 items) | RSS
