Hello
I have a BeoSound 4 CD / Tuner with SD Card and I would like to connect the turntable Beogram 2400 which I have to buy. Can i connect samsung tv
Paweł
Hello Pawel,
Welcome to Beoworld!
As your Beosound 4 doesn’t have a phono pre-amp, you will need this pre-amp kit to connect the Beogram 2400, which comes with all cables needed and full instructions, ready to “plug and play”:-
http://soundsheavenly.com/beogram-record-players/12--preamp-.html – please choose the “Twin RCA plugs” output option for your Beosound 4.
If you can please advise which sockets are fitted to your Samsung TV (eg. headphones, optical digital out, analogue audio out) then I will be pleased to help you get the TV connected to the Beosound 4 as well.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Cześć Steve
Dziękuję za informacje, mój telewizor Samsung posiada Audio Video i wyjście słuchawkowe. Znalazłem w internecie BeoLink Wideo MKII, B & O, model nr: 1615 MCMXCIV może to urządzenie mi pomóc lub po prostu pre-amp Bundle jest konieczne
Hello Steve
Thank you for the information, my Samsung TV has Audio Video and headphone output. I found on the internet BeoLink Video MKII, B & O, model No: 1615, MCMXCIV can this device help me or just Pre-amp Bundle is necessary
Thanks for your reply. If the TV has a headphone output socket, then the simplest option is to use this cable to connect the TV headphone socket directly the to Aux In sockets under the Beosound 4:-
http://soundsheavenly.com/hifi-av/112--trs-2rca-.html
This way, you don't need to buy the Beolink Video converter.
With turntables it's just a preamplifier or there is another option
For Beogram 2400 you need the pre-amp and cables when used with a newer B&O system like Beosound 4. For newer Beograms with a pre-amp built in you just need an adapter cable. I've put together a list of which Beogram models need a pre-amp here:-
http://www.soundsheavenly.com/faq/question/beogram-turntables-need-external-pre-amplifier-kit/
