Hello there guys, a first B&O user here, got my H5 today,and i need help with them.
I own a galaxy S8+, i downloaded the BEO app, and paired my headphones with my galaxy, and the problem is I cant adjust volume on the headphones, i can play and pause answer calls and hang up but the volume is not working, it does work on the phone, and in the beo app, but not on the remote.
Thnx in advance
With kind regards
Bubib5
bubib5:Hello there guys, a first B&O user here, got my H5 today,and i need help with them. I own a galaxy S8+, i downloaded the BEO app, and paired my headphones with my galaxy, and the problem is I cant adjust volume on the headphones, i can play and pause answer calls and hang up but the volume is not working, it does work on the phone, and in the beo app, but not on the remote. Thnx in advance With kind regards Bubib5
Hi there, just this morning i tried pairing it again, and now all works fine, i obviously messed up something on the first try.
But i have another question, i cant seem to get any bass out of them, everything is quite warm, i tried messing about with the app but to nu use, although when i press on the earbuds i seem to get alot more bass.
Thnx for your reply
With kind regards,
For best sound and bass you need to experiment with the supplied different sized ear tips, it is important to use the correct one for your ear.
