Help identifying BeoSound model for a newbie please???
This post has 15 Replies | 2 Followers
roosterman
Posts 13
roosterman Posted: Mon, Apr 24 2017 5:44 AM
Hi there, I'm a complete rookie when it comes to B&O, so please bear with me. : )  My father-in-law just died and he has a BeoSound system with speakers.  I can't work out what model it is though as it has no labels or tags on it anywhere - see attached image.  From what I can see by looking on sites such as this, it may be something like a BeoSound 3000 (or maybe a previous model) with perhaps BeoLab 2500 speakers attached to it so it's all in one piece.  Can someone help by telling me how I can accuraely identify this and roughly how much I should be trying to sell it for?  I'm happy to admit I have no idea on it so really appreciate any guidance you can give me.  cheers, Troy.  PS I'm in Australia if that makes any difference to this information.
CB
> You are Here <
Posts 1,762
CB replied on Mon, Apr 24 2017 6:48 AM
Hi and welcome on Beoworld
The loudspeakers are effectively Beolab 2500.
To help us for the centre part, please post a closer picture of:
  • the keyboard (with something on the display),
  • the CD player without a CD,
  • the bottom left part of the center piece (to see if there is a small windows for the IR receiver).
For me, it looks like a Beosystem 2300 (in bad shape), the antenna and the doors are missing...
Mr 10Percent
So West, Its Now East
Posts 591
roosterman
Posts 13
roosterman replied on Tue, Apr 25 2017 11:50 PM
Hi CB and thanks very much for your reply.  Please see attached images as requested, hopefully this helps.  Yeah it needsa some cleaning up and I have the glass doors to re-attach.  One half of the antenna is there (hidden), the other half appears to have broken off.  cheers, Troy
roosterman
Posts 13
Thanks for your help Mr10Percent.  cheers......Troy.
CB
> You are Here <
Posts 1,762
CB replied on Wed, Apr 26 2017 7:04 AM
Hmmmm
Because of the linear CD player rail, it may well be a pre 2001 "small clamper" BS3000
But I thought there was a touch to access N.Music?!?
And the IR window tells us it's a 2 ways system.
Someone else needs to answer...
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Apr 26 2017 8:05 AM
CB:
Hmmmm
It's am early 2300 because of the 2-way ir window.
BS3000 has the numerical pads in the middle in 2 columns.
/Weebyx
CB
> You are Here <
Posts 1,762
CB replied on Wed, Apr 26 2017 8:43 AM
Weebyx:
I would say "late" BS 2300 then, early had the curved rail.
mauszwerg
Posts 104
mauszwerg replied on Wed, Apr 26 2017 1:16 PM
It is a Beocenter 2300. I have the same one and it was bought in 1995. Straight clamper and capable for two way.
ralf
MediaBobNY
Greenwich Village, NYC
Posts 1,106
You should test the sliding door mechanism with the doors attached.  It's quite possible they were removed because the mechanism is defective (if it works with the doors removed does not mean it will work with the doors attached due to the added weight).  It looks to be in pretty rough condition and with B&O, cosmetic condition is *very* important.   You don't have the remote control I assume.  Here in the States, worth maybe $400 if the doors work.
Stoobietoo
Exeter, Devon, UK
Posts 692
A bit of a long shot, but is there not a cable cover on the back that is covering where the label is? If you cannot see any of the connections sockets, they are behind a removable cover and the label should be behind there.
Stoobie
roosterman
Posts 13
roosterman replied on Thu, Apr 27 2017 11:50 PM
ok cheers mate, I'll have a look this weekend.
roosterman
Posts 13
roosterman replied on Thu, Apr 27 2017 11:51 PM
Thanks for your reply.  I'll test them out and clean it all up.  Cheers! Troy
roosterman
Posts 13
Cheers CB : )
roosterman
Posts 13
roosterman replied on Thu, Apr 27 2017 11:52 PM
Thanks for your help Weebyx!
roosterman
Posts 13
roosterman replied on Thu, Apr 27 2017 11:53 PM
Thanks for your help!!  Troy
Page 1 of 1 (16 items) | RSS
