BeoVision Eclipse 55”, Beolab 18s, Beolab 19s, Beosound 1, Beoplay P2, H3, BeoRemote One IR, BeoRemote One BT, Beoplay S8, Beosound Essence MkII, BeoTime
Regards
Kiran
Born in NL; I ride ML
You can add and remove sources under MUSIC and LIST from the remote's advanced options under LIST.
Kiran:You can add and remove sources under MUSIC and LIST from the remote's advanced options under LIST. Regards Kiran Born in NL; I ride ML
You can (re)name the sources as you please, when setting these up.
And you can decide if or not and where they should appear in the lists on the remote.
See page 24 - 'BeoRemote lists' in the userguide.
Millemissen:You can (re)name the sources as you please, when setting these up. And you can decide if or not and where they should appear in the lists on the remote. See page 24 - 'BeoRemote lists' in the userguide. MM There is a tv - and there is a BV.
Hi Chris,
do you see the option "Text" (Videotext) in your TV-"List"?
BV 14-55 mit BL 18, BL 8000, BL 2, BeoRemote One-BT, ATV 3; BS 9000 & BS Core & BS 4500 mit BL 12-3, BL 12-2, BeoLink 1000; BeoLine mit BC 2, BC 6000; BS 8; BeoVox CX100; BeoTime (analog), BeoTime (digital); Earphone A8; Beoplay H3 + P2
Chris....you have to do it on the tv settings....chose a source from the source list, select menu lists, and go from there.....it is different from the regular BR One...
what you can't do yet (i believe) is (a) edit the Music and TV list that appears on the home screen of the BV14......and (b) when you link a product to the BV14, all of those sources appear on the remote and home screen Music / TV icons......
guessing those latter two cases need to be added as options....
yes, thus far, this is the way it works.....you go through each source (TV as you have shown above), and assign it to either / both / no list.....teh only way to see the results amalgamated list is on your actual remote......
so yes, there is nowhere on the settings menus to see what each lists comprises....only on the actual remote as mentioned above.....peroanlly i haven't found that a problem......or am i missing something.......
the real pain at the moment is that once you link a product, all of its connected sources show up, and there is no way to manage that list as yet....
ah i see..apologies.....not quite sure what you are trying to do....
when you press List on the remote, you will see a whole load of choices....so for me, right now i have :
BV14-55, SKY HD, OPTIONS, TEXT, STAND, SHOW PICTURE, FORMAT, SOUND etc etc......i can't edit that list of choices....
when it comes to the source specific functions, for example i can shift right on the SKY HD, and i get a bunch of SKY HD functions....i don't think you can edit that list of SKY specific functions either...but they seem the same as on a BV11 (for example) when you press menu, and about 7-8 source specific functions came up on the TV screen....dont think they ever showed on the BV 11 remote (for Sky "Record" or "Box Office" etc)....those same functions now seem to get sent to the bluetooth remote.....find them quite useful actually......but seems better than with the BV11 i.e. old system...
anyway, long winded way of saying, no i haven't found anyway to edit either the broader set of choices under List, nor the source specific functions......
ah i see.....with you.......having fun with the 14?
mine seems pretty stable now.....still have remote communication issues.....have to reselect the source and the remote then works.....but mostly all seems relatively fine now.......even enjoying the ability to stream from my phone to the TV (podcasts mainly), but useful i find....
Sandyb:ah i see.....with you.......having fun with the 14? mine seems pretty stable now.....still have remote communication issues.....have to reselect the source and the remote then works.....but mostly all seems relatively fine now.......even enjoying the ability to stream from my phone to the TV (podcasts mainly), but useful i find....
The BV14-55 is in my bedroom. I dont stream to it often to be honest. For most music and radio, it just borrows my Moment, even though that is connected to my main lounge setup......i only really stream Podcasts to the 14 from my iPhone....i listen to quite a few, and that way is a touch quicker than selecting the podcast app on the Apple TV........
yes, i think i'll speak to B&O regarding list management....i don't mind it being done on the TV settings menu's, would like the ability to hide some linked sources firstly, and also edit what shows on the TV and MUSIC icons on the home screen.
I think there is still some part of multi-room that is missing, though struggling to think of exactly what, most of my use cases seem covered......
directly to the TV.....actually quite a nice experience.......i set it off on my latest episode, and it generally cycles through them, newest to oldest until i get bored....dont really googlecast any video content, can't see much need for that myself.......
