nl/ml converter setup
Tassos
Athens
Posts 323
Tassos Posted: Tue, Apr 25 2017 8:14 AM
Hello all,
my set up is the following:
Living Room:
BeoPlay V1, Beosound Moment, and BeoLab 18. The Moment is set up to use TV Speakers. The beolab 18 are connected to the V1 via WISA (Transmitter 1).
Bed Room:
BeoVision 6-26 and nl/ml converter are connected via MasterLink and nl/ml via network link to the router.
Both converter and moment are integrated to V1 and all of the components are updated to the last firmware.
BeoVision 6-26 is set to v.opt 6 and the converter to opt 4 and as an Audio Master.
By pressing radio on the beo4 in the bedroom tune-in starts to play but when you change source in the moment the converter follows. In other words when you listen something in the bedroom you have to listen the same source in the living room or vice versa.
When the converter is set to A Slave, then you can not start the playback in the bedroom using either the beo4 or the app.
To sum it up: The goal is to be able to listen the sources of the BeoSound Moment to both rooms and at the same time be able to active a different source in one of the rooms. For example listen tune-in in the living room and deezer in the bedroom at the same time. All this should be done in a way that local control of the playback is done via a beo4 for the bedroom and moment interface or beo6 in the living room.
All suggestions are welcome!!!! :-)
Chris
Ostend-BE
Posts 1,170
Chris replied on Tue, Apr 25 2017 10:41 AM
akoitidis:
There is simply no suggestion to this.
You have only ONE master audio source to provide music to your complete B&O setup. Keep in mind that the Moment only can provide one music source and not both (Radio + Deezer).
If you want to listen to different music sources, then you have to install another master audio source to your setup, Per example: a Essence or M5 or....
Then you can provide radio from the Essence to your bedroom and another source (Deezer) from the Moment to the living room. In using more NL audio devices you can use 'join' and send more music sources to different listener positions.
"Believe nothing you read and only half of what you see, let your ears tell you the truth."
Tassos
Athens
Posts 323
Tassos replied on Tue, Apr 25 2017 11:50 AM
Thank you very much :-)
Page 1 of 1 (3 items) | RSS
