When I opened this Beomaster 2000 type 2919, and put the circuit board 3 in the service mode, all of the contacts P1 - P4 disconnected. In order to not confuse the connectors I wonder if anyone can help me with were and in which direction the respective contact is to be connected?
This is how I found the downside of the board 3. Were fill they be connected?
Thanks in advance.
/Di ck
http://tinyurl.com/qj9cjsf
Their pins are offset to one side so they will only fit one way and they have different number of pins so it should be straightforward.
Thank you, Martin.
I dared not take a chance, but as you wrote, the location of the connectors were self-explanatory.
