Hi Does anybody know if a beotime clock will control a beosound 2 2017
thank you Gary
No. The Beosound 2 does not have the IR receiver for the BeoTime.
L1NO:No. The Beosound 2 does not have the IR receiver for the BeoTime.
Hi Gary,
Unfortunately, Beotime can't control the new Beosound 1 or 2, as they don't have IR input sensors. However, Beotime can be set to switch on any older B&O audio or video product via infra-red remote control when the alarm comes on. There is also a "hidden" menu on Beotime to give you full control of your lighting when the alarm comes on, you can see full details here:-
http://www.soundsheavenly.com/faq/can-i-set-my-lights-to-switch-on-automatically-from-my-beotime-remote-using-the-alarm-function/
Kind regards, Steve
Steve.
Aussie Michael:But You can turn off all NL products with it. I've done it with mine.
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:Really? You don't have any ML products that pickup the IR signal and send it to NL devices over a BLC?
Can you switch Beosound 2 off stand-alone with Beotime without connection to another NL-device, too?
TWG:Can you switch Beosound 2 off stand-alone with Beotime without connection to another NL-device, too?
Aussie Michael:No ML products. I can even change the channel with my Avant
