I picked up a Beogram 2400 Type 5716 turntable, which has the controls on the deck inside the dust cover. The only manuals I can find are for the Type 5722 with the controls on the front and the 5716 seems to have more in common with the Beogram 1900. It also came with the MMC 4000 cartridge and not the 20EN as most 2400s seem to have. As pictured.
It needs a new belt and would appreciate knowing if the different 2400 variations take the same size belt? The ones for sale don't differentiate by model Types so wish to check before looking for one.
I am basically on borrowed time as the belt was slack and I tightened it up for now by dropping it in boiled water for a few minutes. Thanks
It actually has very little in common with Beogram 1900 (which uses an AC motor and a round belt).It's far more like Beogram 1902 (DC motor and flat belt).I can supply the correct belt. Email me.
Will do. For information though, do all the variations of the 2400s use the same belt?
There are only the two - and they do.
