Large size horizon
This post has 8 Replies | 0 Followers
vlohjr1
Posts 553
vlohjr1 Posted: Sat, May 13 2017 11:55 AM
I fancy a big screen but don't want to spend too much do you think there would be market for a 65 horizon?
Aussie Michael
Melbourne, AU
Posts 3,730
vlohjr1:
Yes. Or at least a 55
SHEFFIELD
Posts 262
SHEFFIELD replied on Sun, May 14 2017 9:39 PM
Horizon won't be going any larger than 48". 65" screen is always going to be pricey, and you never know, maybe B&O might be bringing out a 65" model...?
Chris Townsend
Qatar
Posts 3,531
vlohjr1:
So would i, if the 7-55 ever packs up. After buying the 5s, it's a tough call to spend £10,000 on a television Unsure
Millemissen
Flensborg, Denmark
Posts 14,680
We don't know - but you do ;-)
Probably just a question about when!
Asking for a bigger Horizon could have two reasons.
1: The wish for a bigger B&O-tv at a reasonable prize (the Horizon is a relatively inexpensive B&O-tv)
2: The poster likes the design (however, will it look good at 65"?)
I don't expect a 'soon to come' 65" BV to be 'inexpensive - the will be pretty expensive.
Maybe later we might see a somewhat cheaper model based on the LG LCD-tv's...
....who knows ;-)
vlohjr1
Posts 553
vlohjr1 replied on Mon, May 15 2017 8:29 AM
Chris Townsend:
So would i, if the 7-55 ever packs up. After buying the 5s, it's a tough call to spend £10,000 on a television Beovision 7-55 Mk2, Avant RF 28, Beolab 5, Beolit 15, Beoplay A1/A2, Beocom 2, Beotime, H3 ANC/H8/H6/H2, Form 2, Beoplay A3, Beovision 5-42 connected to a DVD1
Exactly Chris not fussed about glass motorised stand magic etc just a big screen with reasonable tv speakers and nl integration
One can hopeErm..
AnalogPlanet
Vienna, Austria
Posts 678
I would personally prioritize a change of panel in Horizon - current one is an outdated and cheap one normally found in 600 EUR TVs.
Once that happens (if?), I am okay with the 48" version but would even prefer 55" a bit more. Plus, I am CRAZY about Horizon's design and specifically wheel stand setup. <3
So I'll buy it in a heartbeat but never with the current panel.
boskonay
Posts 76
boskonay replied on Mon, May 15 2017 10:49 AM
I've a 48" Horizon, which we love, but would upgrade to a 55 in a heart beat if they did one (can't justify the cost of an avant for a kids / play room)
Millemissen
Flensborg, Denmark
Posts 14,680
A 55" would be fine for me too (if it wasn't Android-based).
But I don't expect that to happen, now that the BV's will be made with/by LG.
Maybe we will see something better in that prize range later on.
Page 1 of 1 (9 items) | RSS
