Hi all I have a Beogram 3000 Type 59xx and someone has cut the 7 pin Din plug off, can anybody please help with a wiring diagram for the Din Plug so that i can solder a new one, many thanks Sean
Have you looked for it in the manual section? No access - then upgrade to silver / gold.Look out for transistor TR 11 at P6. Pin 7 goes to the Collector - it serves as datalink.
