I'm trying to control the volume of my speakers (which are plugged into my beosystem 3), via the beoport pc app. Does anybody know how to do this, as i am stumped?
thanks
Not sure what you mean?
The Beoport software running on a PC is for connecting to the BeoMaster 5.
The volume of the (speakers connected to) BSys3 is controlled using a B&O physical remote/ir.
Could you be a bit more specific.
