Essence mii & beolab 4000
Peter
Denmark
Posts 1
Peter Posted: Mon, May 22 2017 8:26 PM
Hi
I need help on my essence. I have no sound on the connected speakers beolab 4000. Whenever I start something the speakers turns from red to green and clicks are heard. But no music. Also the play list goes mad . Any ideas ?
I have a telenor router.
/peter
Mark-N
Maryland, USA
Posts 320
Mark-N replied on Tue, May 23 2017 9:50 AM
What are you playing? Is it music from your library using DNLA?  Did you try playing something from Tunein or another source?
I have a similar problem when I am playing high-resolution tracks that I purchased through HD-Tracks using DNLA.  Looking at BeoMusic, it looks like it's playing for a while, but after about a minute through a 4 minute track it will then go to the next track.  I reported this to BeoCare a long time ago, they asked for samples, which I provided, and never heard anything back again.  It still doesn't work!  I can get these tracks to play using Airplay, but I am sure they are being downsampled.
Try another source and if you have Airplay or Google Cast try streaming using that.
Mark-N
Maryland, USA
Posts 320
Oops!  I didn't think I hit Post the first time! The response was very slow!
Beroli
Germany
Posts 316
Beroli replied on Tue, May 23 2017 10:15 AM
Hi Peter,
Here are some questions.
Have you tried to update the essence to the latest version?
When you enter setup mode (in BeoSetup-App, or BeoMusic, or new X-App, which sources have you activated?
Is your remote (eesence wheel) conected (in the remote section of your essence)?
If nothing helps, try a restart or in the worst case a factory reset.
Usually it is a good sign, when the Speakers are activated.
Cheers Beroli
Stan
Chicago-area USA
Posts 869
Stan replied on Fri, May 26 2017 7:55 PM
This is what mine does when I try to play lossless WMA from my BS5 (not supported by Essence).  Definitely try to play TuneIn or something easy before moving to audio files.
Page 1 of 1 (5 items) | RSS
