Please check the order of your local sources using the BeoSetup or a web browser pointing to http://<M5 IP address>
Go to: Your content / sources / in local list and make sure only your active sources are up and put Tunein first in the list
Yes, that was it. I used the browser. Works fine now.
Thanks a lot mbolo01.
You are welcome, and if you don't know the tip already, by turning while pressing the wheel you navigate through your preferred TuneIn stations.
Yes, I did know. But, thanks anyway.
I hope that future firmware will allow for further reducing the bass. I've set it to corner.
