Hi all,
I have a Beomaster 5500 without beocord in the main room. I hooked up my old pioneer minidisc deck, in one of my MCL link rooms, because as an experiment I would like to record from a local analogue source that I have connected to the CD input of the MCL2 A/V (my laptop). I connected the minidisc's output and input to the TAPE socket on the MCL2 A/V with a 5 pin DIN to 4x female RCA. The problem that I have is that I cannot get an input signal to my minidisc recorder to record.
I can of course directly link my laptop to the minidisc's input, but it has become a quest to make it work, because I have the feeling it should be possible if I only know how to "open" the tape-out in the link room. I have a master control panel 5500 in the study to switch on the system, but I have also beolink 1000 around if needed. I tried many key combinations already to no avail.
Anyone ever tried recording in a link room with a non-datalink tape recorder or has a better understanding of getting the output to work?
Thank you in advance!
Beosound 5 Encore + Beosystem 5500 + S45.2; BV7-40 MKV + BL7.1 + BL14.4+ AppleTV4; various link rooms with MCL2 A or MCL2 A/V + RL60.2 / CX100 / CX50 & Cona / IWS2000; BG4000; Beosystem 1200 + BV1600.
Anyone? Perhaps some experience with using an old tape deck (pre-datalink) on a datalink system or in a link room?
Thanks!
Sorry, I solved it already: the wiring of the 5pin DIN to 4 Phono plugs was different that I expected, and so I was playing through the output leads all this time (hence the low output volume from the MD). I started swapping cables and adapters systematically until I knew how it had to be done. Now I can just record whatever is playing in my link room or in my main system, which is pretty neat.
Warning for those who ever want to use this (although I doubt it): do not select aux + 6 in link room if you are recording or your recorder is paused, because you will hear a nasty buzz sound being amplified over and over again. I think my recorder has protection, but just to be safe: don't select that channel as "source", any other source is fine.
