I have 37000 flac files stored on qnap nas.the problem is mots don't go any further then 15%.
No corrupt files and the strange is,if i load them in the beomaster5 harddrive then everything is ok.
Anyone an idea why the nas stays at 15%
Hi.
What are the sizes of your files ? Beosound 5 is on CE I think and will use fat file system
Beolab 1, Beovision 7-32, Beosound Moment, Beolab 18, Beolab 19, Beoplay A6 Grey, Beoplay A6 Black, Beolit 15, Beoplay H7, Beosound Essence mkII waiting for speakers :)
Flac files are plusminus 22mb a song.
If i stored the same music on the beomaster5 mots will go to 100%,but via nas 15%
I'll have to do a count but I'm up at 35-40k's worth of tracks. MOTs is working fine.
Suggest you linkup a keyboard and mouse, go into maintenance mode/pc mode and delete all the MOTs files.
Exit, reboot and let MOTs do its work. It will take a couple days to run through to 100%
10
It's allready done but with no luck...still 15%
is it possible that the BS5 got stuck on name taging. for example songname - (Marie's The Name) His Latest Flame
Albumname - #7
koning:is it possible that the BS5 got stuck on name taging. for example songname - (Marie's The Name) His Latest Flame Albumname - #7
koning:It's allready done but with no luck...still 15%
The problem may come from the NAS...
Did you change any settings?
Is there some kind of energy saver on? (may be the disks are stopped after some time)
Koning:If i stored the same music on the beomaster5 mots will go to 100%,but via nas 15%
I understand the OS are different. They may not react the same way...
No disc stopping,24/7 working.
