Cameras
djfairley89
Posts 20
djfairley89 Posted: Fri, May 5 2017 9:17 PM
Have some Hikvision cameras run on a DVR HD - will gateway link in with these or does it need to be NVR type?
Appreciate any advise
Dave
Kiran
UK
Posts 1,023
Kiran replied on Mon, May 22 2017 9:55 AM
Don't worry about DVR or NVR. You don't need this unless you want to record.
The BLGW pulls the stream directly from the cameras and after the firmware update on the BLGW, it now supports cameras with H.264 stream - so set your Hikvision cameras to H.264 and then input every field correctly under cameras in the BLGW for it work properly.
Before, it was only the ancient MJPEG stream supported by the BLGW...
Regards
Kiran
Born in NL; I ride ML
StUrrock
Posts 995
StUrrock replied on Sat, May 27 2017 8:29 AM
If you can't discover the actual video stream path, download the freely available Onvif Device manager for PC it will tell you all you need to know.
Page 1 of 1 (3 items) | RSS
