Please help
I purchase BC2 vwth DAB ACC socket unit.
I found 12 DAB stations but no soud on the spekers.
Signal is not bad.
FM ,CD,aux working ok.
any help please.
nobody can give me hint :(
Do you get any sound from FM stations?
Hi Lee
Yes ..FM working fine :)
Then I'd say the DAB module is faulty. I've had this before. Normally it just won't tune in, but if it's tuning in and going silent there's clearly another issue in there....
Hi, It is because you have a unit with DAB module. What you need is DAB+ module instead.
Upgrade kit for DAB -> DAB+ is available from B&O.
i undarstand part ...but.
My BC2 receive 12 DAB stations on DABmultiplexR1 with no probem.
Antena receiption is fine.
it's just no sound on speakers when i have DAB stations in screen.
so...no idea what the problem is :(
marexy: i undarstand part ...but. My BC2 receive 12 DAB stations on DABmultiplexR1 with no probem. Antena receiption is fine. it's just no sound on speakers when i have DAB stations in screen. so...no idea what the problem is :(
The problem is that the BC2 is able to find the DAB+ stations, and show them to you, but it cannot decode the sound stream, so you will have no sound.
Your problem is because you need the DAB+ module in the BC2.
/Jacob
