I recall that a similar issue was reported (Hjort?), couldn't find that topic - but my 1 week old BS1 just stopped playing.
The little speaker light is on, tapping on the tab will make touch button flash briefly but nothing more than that. No sounds of connecting (a bit louder beep that is).
Can't connect via network / bluetooth. Any suggestions on what to do? I unplugged it but later realised it has a battery . Just so typical, as 5 minutes before I told my wife how much I liked it.
There is a power button underneath to switch off altogether.
Did you check that the software is up to date when you bought? there has been a recent update released.
You cold also try a reset using the pin hole underneath.
Opman
Nice - so don't forget to (re)tell your wife, how much you like it ;-)))
Yep, I had a similar problem. It has not behaved badly since then
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Well, not so good sa far - unfortunately.
A few times already my wife finds the BS1 just going on by itself at very loud volume.When turned off, by tapping on the top, it goes on again by itself. Latest firmware, no timers programmed, only plaing Tune-in or directly from iDevice via network.
Now it showing red light - my wife has resetted the unit - or at least tried.
Is a trip to my B&O dealer the next step to take?
Ferdinand:Well, not so good sa far - unfortunately. A few times already my wife finds the BS1 just going on by itself at very loud volume.When turned off, by tapping on the top, it goes on again by itself. Latest firmware, no timers programmed, only plaing Tune-in or directly from iDevice via network. Now it showing red light - my wife has resetted the unit - or at least tried. Is a trip to my B&O dealer the next step to take?
