Hi All,
i have a yamaha rx-v 2067 surround receiver and bought the trigger cable with 2 phono on but when i connect the 2 speaker there is a lot of noise, bought a audioquest rj45 cable
i have 2 old beolab 6000 speaker that i have connected with the old din cables and they work perfect with the trigger cable
so either it is the rj45 cable or the beolab 18 speaker that is the problem
does anyone know what the problem can be
Best Regards
Michael
