Beolab 20 connected via Toslink to Airport express
This post has 13 Replies | 1 Follower
lonfred
Posts 200
lonfred Posted: Fri, May 19 2017 2:37 PM
Hello, I just wonder if anyone here has connected a couple of Beolab 20 via Toslink to an Airport Express? In that case what is the experience? Would the volume level be adjustable from the IOS unit? What about sound quality? Will the Toslink connection put the loudspeakers in standby when not used and put them on when used?
Best regards
elephant
AU
Posts 8,219
elephant replied on Sat, May 20 2017 4:30 AM
I use GoogleCast device rather than an AE - and yes, speakers turn in and off in step with the source starting to play or stopping the play.
Volume is adjustable from iPhone but you mus keep it quite "low" as it is very easy to have BL20s SHOUTING rather than singing.
Quality is good.
BeoNut since '75
lonfred
Posts 200
lonfred replied on Sat, May 20 2017 8:03 AM
Thanks. Sounds good. I will try a chrome cast solution when I receive the speakers and then later I think I will add an Beosound Core or an updated Moment.
elephant
AU
Posts 8,219
elephant replied on Sat, May 20 2017 8:57 AM
The google audio puck is cheap enough that you will barely feel any pain if you decide you don't like it !
BeoNut since '75
lonfred
Posts 200
lonfred replied on Tue, Jun 27 2017 12:05 AM
Just received two Beolab 20 today and has connect them via WISA to an Beolab Transmitter 1 that is connected to an Google Cast via Toslink. Works really good both with Spotify and Deezer and with Deezer I also get tone control. SmileSmileSmileSmileSmile
CB
> You are Here <
Posts 1,762
CB replied on Tue, Jun 27 2017 7:01 AM
Congratulation for your new Beolabs Thumbs Up
You can also try TuneIn for the radio, DS Audio (if you have a Synology NAS) and other Android apps...
lonfred
Posts 200
lonfred replied on Wed, Jul 5 2017 6:56 PM
Connected the Beolab 20 yesterday via wisa to a Beosound Moment. The improvement of sound quality is impressive compared to the ChromeCast-toslink-Beolab transmitter-Beolab 20 solution. Will stay with the Moment solution. With the Moment I also get tone control and control of the left and right speakers and much more stability than the ChromeCast solution.Big Smile
CB
> You are Here <
Posts 1,762
CB replied on Wed, Jul 5 2017 7:10 PM
That's interesting !
Did you play the same exact song ?
Did you also compare with a direct connection of the Chromecast via Toslink to the BL20s (i.e. without transmitter) ?
lonfred
Posts 200
lonfred replied on Wed, Jul 5 2017 7:32 PM
Yes same Coldplay songs. Also tried direct Toslink connection between speakers and ChromeCast but same result as with the transmitter. Much cleaner and more deep in the sound with the Moment. The Beolabs 20 in this way is fantastic speakers.
elephant
AU
Posts 8,219
elephant replied on Wed, Jul 5 2017 10:30 PM
Which Coldplay songs and which source e.g. Deezer ? Free or fee ?
BeoNut since '75
lonfred
Posts 200
lonfred replied on Wed, Jul 5 2017 11:01 PM
I used Deezer fee
Coldplay, A sky full of Stars and Viva la Vida.
With ChromeCast it did not feel as harmonized as with the Moment. More like, now it's time to deliver bass, now it's time to del live tweeter etc
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 6 2017 11:29 AM
Listening to Coldplay (as below) > Deezer fee > Essence > powerlink > BeoLab 20
Can't say I am experiencing the -ive effect you described
I'll try my GoogleCast optical connection later
With their 2012 Live ...
BeoNut since '75
elephant
AU
Posts 8,219
elephant replied on Thu, Jul 6 2017 11:46 AM
GoogleCast setup for tomorrow's tests ...
Sample test ... optical connection always sounds fuller / louder to me
BeoNut since '75
lonfred
Posts 200
lonfred replied on Thu, Jul 6 2017 11:49 AM
I suppose your Essence do the work with the sound simular like the Moment. And I also suppose you get tone control with the Essence too.
Page 1 of 1 (14 items) | RSS
