Hi all
please help? one of my speaker lights stays green with no sound i have tried all the normal tricks changed the speakers around and switches ? i had them upgraded two years ago< i think its a internal fuse is this something i could attempt to fix my self?????????
regards all
colin
THOUGHT I WOULD TRY AGAIN AS I GOT NO RESPONSE WHEN I ORIGANALLY POSTED THIS
MANY THANKS COL
Check the internal connections to the speakers.
Are you sure it is not set to LINE in the connections?
Jonnie
I know you said you changed the speakers around, but did you change the wires around? Problem I had. New cable fixed the problem.
