Searching archived forum
This post has 1 Reply | 0 Followers
PaBEO
Posts 5
PaBEO Posted: Sat, Mar 3 2012 5:13 PM
Hi everyone,
Was intending to sit down to a session restoring my beocenter  4600 using an old post on cleaning grease from a brass pin to get the tonearm to behave, and although I can get into the archived forum the search function does not appear to be working for me...
have I missed the way to search through the archived forum pages? Thanks in advance!
tournedos
Finland
Posts 7,357
You're right, searching doesn't currently work in the archives - we're sorry for the inconvenience.
It will be fixed eventually, but meanwhile I think this thread might be helpful. The turntable section in your BC4600 is practically identical.
--mika
Page 1 of 1 (2 items) | RSS
DigiCert Secured Site Seal
